09-05-2004, 08:53 PM   #1 (permalink)
nashville
Soft Shift to second and third
fresh rebuild, blue clutches, kolene steels, kevlar bands, transgo 40-3 full manual kit, modulator in, but not hooked up, H servo
when it shifts from second it feels a little soft.
is this band adjustment issues?
Brad
ps
transmission was airchecked, and valve body put on a machine and checked before it was installed
<font size=-1>[ This Message was edited by: nashville on 9/6/04 8:54am ]</font>
nashville is offline   Reply With Quote
09-06-2004, 01:18 AM   #2 (permalink)
justinb67
do you know the clearances on the high-reverse?
It is possible it is the intermediate band adjustment, but more likely the high-reverse clearance.
Justin
justinb67 is offline   Reply With Quote
09-06-2004, 05:30 AM   #3 (permalink)
gregaust
Are you using a high stall convertor?The convertors can cushion the shifts at light throttle and make the shifts feel soft..It should shift harder though up in the revs.
09-08-2004, 09:46 PM   #4 (permalink)
nashville
yes using a h igh stall converter, took to track labor day, it ran good, but its like you could never feel it shift, first to second or second to third
just an instant change from 1 to 2 and from 2 to 3, with no slip what so ever, but no hard thump when it changed gears[img]/phpBB/images/smiles/icon_confused.gif[/img]
<font size=-1>[ This Message was edited by: nashville on 9/9/04 9:47am ]</font>
09-09-2004, 02:49 AM   #5 (permalink)
justinb67
high stalls slip, that is what gets you the high stall. The side-effect is soften shifts. The shifts may be firm, but since the converter is not as tightly locked with the engine, it does not pull the engine down in revs as instantaneously, or completely for that matter.
I thought you were having problems with *only* the 2-3. But if you just put in a high-stall and your getting soft shifts from 1-2 and 2-3, then that is normal. Surprised the heck outta me the first time I put in a high-stall.
Justin
<font size=-1>[ This Message was edited by: justinb67 on 9/9/04 2:50pm ]</font>
09-09-2004, 08:19 AM   #6 (permalink)
nashville
im talking soft shifts at 2500 rpm, 5000 rpm, 7000 rpm
doesnt matter, they are all soft, its only a 3200 stall,
09-09-2004, 08:58 AM   #7 (permalink)
PhatFalcon
Just listening to an automatic door slammer set up similar to your at the track sounds like soft shifts down the track, but the car moves smoothly. No jerkiness under full throttle.
<font size=-1>[ This Message was edited by: PhatFalcon on 9/9/04 9:00pm ]</font>
09-11-2004, 10:48 PM   #8 (permalink)
mavman
That's how C4's shift. They don't jerk or bang like those GM trannies do (my 'glide will hurt you if you aint' ready for it-but it's hard on the drivetrain). Every C4 I've ever had was like you describe. A quick shift is better than a delayed hard shift anyday.
