leaking from pan
Here's how I seal ours - clean and flatten the pan surface, then I use a very, very THIN coating of something like Hylomar - really just enough to stick the gasket. Put the pan on the bench with the gasket down and some weight on it until the sealer takes a good hold. You can use RTV, but user VERY LITTLE. So thin you can hardly tell any is on there, then let it set for an hour or so. If you can find a flat trans pan gasket, you can really skip all this. When I get them local (in a pan/filter kit) they come out of the box looking like orgami.
To put the pan on the trans, clean the gasket surface with brake cleaner. Get it good, clean and dry then install the pan/gasket DRY, no sealer.
