04-20-2005, 12:56 AM   #1 (permalink)
pmoylan
loosing oil from breather vent?
hey all,noticed my c4 is spitting fluid out the breather when it gets a workout,any clues as to why??its got a deep sump,its not overfull,well not according to my dipstick,should the same level be used when using a deep sump,on the dipstick i mean??
pmoylan is offline   Reply With Quote
05-13-2006, 09:18 PM   #2 (permalink)
67falconer
I have the same problem.
Anyone?
67falconer is offline   Reply With Quote
05-14-2006, 09:02 AM   #3 (permalink)
chipmechanic
Well it is a small case and under hard acceleration it could just slosh back to where the breather is . It wasnt really designed to be a high performance transmission. The powerglides are known for puking too and many race tracks require a puke tank be used with them. Perhaps having a puke tank on a severe duty c4 would be a good idea.
chipmechanic is offline   Reply With Quote
05-14-2006, 11:22 AM   #4 (permalink)
elwi
I had the same problem in a hard right corner.
The spilled fluid directly hit my exhaust causing a lot of smoke. (upsetting the fire guards on the track)
I solved the problem by installing an overspill canister.
Make sure to make a vent hole in the top of this canister, so the gearbox can still breath.
Good luck!!!
Harry
elwi is offline   Reply With Quote
05-14-2006, 02:27 PM   #5 (permalink)
gregaust
I have a catch can on mine with a small breather on it but i mounted it higher up in the back corner of the engine bay.
