2-3 FLARE IS THIS BECAUSE I HAVE NO KICK DOWN LINKAGE?
I JUST PUT A C4 INTO MY 87 EFI CAR. I DID NOT PUT A KICKDOWN LINKAGE SETUP ON IT AND I THINK THIS MAY BE MY PROBLEM WITH THE FLARE. 1-2 IS STRONG 2-3 FLARES BUT NOT AT LOW RPM. I ADJUSTED THE BAND WITH LITTLE LUCK. WILL A MANUAL VALVE BODY CURE THIS AS WELL. I BOUGHT THIS TRANS FROM A GUY THAT SAID HE JUST HAD WORK DONE TO IT WITH 10,000 MILES ON IT AFTER THE WORK. ALSO I HAVE A 3000 STALL. I AM THINKING OF A NEW SERVO ALSO. IF I NEED THE KICK DOWN ANY ONE EVER MAKE ONE FOR A EFI CAR THANKS
