12-17-2005, 06:02 PM   #1 (permalink)
Aussie65
c4 driven gear
need to know where i can get hold of a 25 tooth driven gear for my c4. I'm led to believe that the biggest is 20 teeth. Am running 24" tyres with 3.77 gears and 8 tooth drive gear. How far out would my speedo be if i run a 20 tooth?
Aussie65 is offline   Reply With Quote
12-18-2005, 05:46 AM   #2 (permalink)
gregaust
c4 driven gear
The highest gear teeth i know of is 21T.There are some listed in the ford motorsport catalogue that go higher but from memory dont know if they are for c4's.
12-18-2005, 04:14 PM   #3 (permalink)
jay427sohc
c4 driven gear
The highest Im aware of in a 23 tooth. You need to use a ratio adpator or change to a 7 tooth output shaft. Im assuming you have an 8 tooth now.
jay427sohc is offline   Reply With Quote
