transbrake
Our "old" PA brake is slow, we leave off the 2nd amber on a .400 full tree which makes TOTAL reaction time (me/brake release and car) around .8...or is it 1.2? Whatever...its slow. I think it could be sped up abit but it would mean a larger solenoid. The way it works is by releasing pressure in one of the valves in the VB , when you have your finger on the button. This "release" of pressure engages the direct clutch. When you take your finger off the button that valve must be engaged again to release the direct.....and it does so through a VERY small hole in the seperator plate....hence the slow brake release.
If you increased the size of the hole in the seperator plate to get more flow to that valve, I don't think the solenoid bleed off (size) would be large enough to handle the addition flow and the brake most likely wouldn't work. To put it simply, fluid flows thru a small hole into an area that has a valve and the solenoid connected to it. The solenoid allows the fluid to drain out of the area because the small hole is restricting flow so much, the solenoid can drain it faster than the hole can supply it. When the solenoid is closed, the small hole must fill the area again and move the valve (which has a stout spring behind it) to its "on" position ....to release the direct and "free" the trans.
I'm sure it could be done, but would take some carefull experimenting with a larger hole size solenoid and enlarging the bleed hole to suit.
