05-02-2006, 11:27 AM   #11 (permalink)
Mario428
Manual downshift?
On 2006-05-02 08:55, 64TBOLT2 wrote:
Exactly. And without it, I've seen the trans shift by its self on the 2-3
if your shifting manually it shouldnt shift by it self.you should be able to hold any gear till the engine blows
Maybe you should be able to but there is plenty of evidence that you cannot.
Kickdown pressure does help hold the shift valve in place.
05-02-2006, 04:05 PM   #12 (permalink)
ckelly
Manual downshift?
You'd think - and all the kits say you can - but it might. It may be a govenor issue, but it can happen. Fought it on the Mustang, trans would shift 2-3 at between 5400 and 5800. Same with B&M kit and with TransGo. Had the VB out of that trans a bunch. Finally bought the Lokar stuff like I have on the Falcon for kickdown - problem solved. She's already tested the 6500 RPM limiter in second.
05-05-2006, 10:31 PM   #13 (permalink)
63SportsCoupe
Manual downshift?
I had same problem without kickdown in place...replaced prior manual/auto VB kit with full manual forward shift pattern transgo kit and eliminated problem.
63SportsCoupe is offline   Reply With Quote
05-08-2006, 04:17 PM   #14 (permalink)
kmracer
Manual downshift?
so.. how does one go about adjust the kickdown? i want harder shifts.
kmracer is offline   Reply With Quote
Probe Industries
