05-05-2006, 04:41 AM   #1 (permalink)
64comet
Aftermarket input shafts?
Built a C4 for a friend--now he tells me he has an early 24 spline converter . Is there an aftermarket input shaft that will allow him to use the early converter in the late transmission? I hate to have to hunt for an early pump stator, high and forward drums just to accomodate the converter and sacrifice strength. Mid 80/s Mustang, hot 351 and a lot of spray. Thanks for your inputs.
64comet is offline   Reply With Quote
05-05-2006, 05:37 AM   #2 (permalink)
Stuarta
Don't bother.
It isn't worth the hassle.
Stuarta is offline   Reply With Quote
05-05-2006, 01:51 PM   #3 (permalink)
gregaust
Your friend now needs a new converter. Don't go backwards.
05-06-2006, 06:54 PM   #4 (permalink)
tonys10sec306
use what he has already
05-08-2006, 04:33 AM   #5 (permalink)
igo1090
assuming its a high dollar converter & worth it, have it cut & the correct turbine hub put into it. might cost 200-300 dollars. also have internals checked out and stall adjustment made, if needed. as long as its open.
igo1090 is offline   Reply With Quote
