05-06-2006, 06:34 AM   #1 (permalink)
taxx
C4 Puking and Slowing in 2nd
Hello all. I recently rebuilt my C-4 following the haynes ford transmission manual step by step. I put a B&M transpack kit in it. Everything seemed fine. Got my 302 running recently and took it for a spin. 1st gear and reverse it runs great. Once I hit second it starts puking smoke out the breather hole (I can see it through the big hole in my floor) and it actually seems as though as I give it more power the slower I go. I can really hear the engine strugling as the tranny forces it to slow down.
Any ideas what to check?
taxx is offline   Reply With Quote
05-10-2006, 02:00 AM   #2 (permalink)
forthman
Hmm bands?
05-10-2006, 07:01 AM   #3 (permalink)
ckelly
Maybe you've got two gears fighting each other - bands not releasing, rev/high clutch too tight, valve body not assembled correctly or warped from overtorquing, etc.
Power flow:
1st - low/rev band applied, Forward clutch applied
2nd - low/rev releases, interm. band applied, forward clutch applied
3rd - interm. band releases, rev/high clutch applied, forward clutch applied
05-11-2006, 07:29 PM   #4 (permalink)
mavman
leaky valve body...causes the low/rev band to partially apply while the int. band & forward clutch are applied. This causes it to partially lock...at one time I lost control of my Maverick on the drag strip because of this. didn't hurt anything buy my pride and toasted the transmission...but a good valvebody and another rebuild fixed it. I still use that transmission in my Mustang. That was over 7 years ago.
I guess it's time to overhaul that thing. Naaa...hell...It still works.
05-12-2006, 06:45 AM   #5 (permalink)
ckelly
I was thinking the same thing about mine - almost 10 years and a billion passes. Still flares on the 2-3 in the pits, never on the strip - go figure.
