08-06-2006, 02:15 PM   #1 (permalink)
65whiteFastback
Help me figure out what I need Please
I just bought A rebuilt C4 and it turns out its a pan fill. So I have a couple questions.
1) Can I use my case fill bellhousing on the pan fill trans? If I read other posts correctly I can do this and use longer bolts?
2) If I do use my case fill bellhousing does that change which converter I use? I see TCI list different converters for case fill vs. pan fill.
3) Is it hard to find a dipstick and tube for a pan fill?
Thanks, Ron
65whiteFastback is offline   Reply With Quote
08-06-2006, 03:29 PM   #2 (permalink)
gregaust
1) Yes you can.
2) Use the case fill type converter that matches the bellhousing
3) Several companies (P.A,Hughesetc) offer screw in pan fill dipsticks with the lockdown top
08-06-2006, 03:43 PM   #3 (permalink)
What in the hell is a case fill C-4?
Give this tranny dummie some what's what please....
FE
08-06-2006, 04:03 PM   #4 (permalink)
65whiteFastback
A case fill is a C4 that the the dipstick tube goes thru the case.
08-06-2006, 04:04 PM   #5 (permalink)
Lupins
Case filled is where the dip stick tube is plugged into the case the trans fluid passes through the case to get to the pan.
Lupins is offline   Reply With Quote
08-06-2006, 08:27 PM   #6 (permalink)
Ooooohhhhh and then there is a C-4 that has the dipstick tube in the pan I take it? Is this an early or late C-4 with the dipschtik in the pan?
FE
08-06-2006, 08:55 PM   #7 (permalink)
forthman
Lots of trucks and vans came with the pan fill C4.
Holley
