10-22-2006, 03:58 PM   #1 (permalink)
boullestergm
C6 build for a 4x4 truck
I'm helping a friend out with his C6 and had a few questions about shift kits and servo levers.
Normally when I build a C4, it's for a hot rod and a no brainer (for the application) to go with a manual valve body. Since this C6 is for a truck and will need to keep the automatic functions what sort of shift kit would you recommend? I see that TransGo and Superior both offer kits.
One of the items that we did go with was one of the billet "R" servos. The servo lever is a new thing to me though. Ours is an "A" lever. I did a search and saw that it has a 1.65:1 ratio. I see that others have a better ratio, but would it be worth changing? How exactly do you change out the lever? I fooled with it a little but didn't see how to remove the hinge pin.
I appreciate any feedback,
Gerald.
boullestergm is offline   Reply With Quote
10-22-2006, 07:59 PM   #2 (permalink)
gregaust
Use a 67-2 transgo kit.
Just go with the servo ,leave the lever. Too much servo and lever multiplication can crack the case.
10-23-2006, 02:51 AM   #3 (permalink)
Stuart1
If you really want to replace the lever there is a welsh plug in the front.
But like Greg says. You can split the case.
Stuart1 is offline   Reply With Quote
10-23-2006, 04:38 AM   #4 (permalink)
boullestergm
Thanks for the info. I'll put it to use.
10-25-2006, 05:53 AM   #5 (permalink)
boullestergm
I have another question. How many welsh plugs does the C6 have in it?
I ask because we found a welsh plug in the bellhousing area and we don't know if it came from the tranny or is just road debris (he didn't have an inspection cover at the time). I check the welsh plug for the servo lever and it's still there.
Sorry about asking, but I don't have an ATSG for the C6 and the Haynes doesn't really talk about any welsh plugs.
Thanks again,
Gerald.
10-25-2006, 12:57 PM   #6 (permalink)
Stuart1
That's probably out of the starter.
There is only one in the transmission.
10-26-2006, 05:44 PM   #7 (permalink)
393Clevor
http://www.topham.kicks-ass.net/C6/index.htm
11-01-2006, 03:06 PM   #8 (permalink)
boullestergm
The C6 is up and running and my neighbor tells me it shifts about a 100x's better than before. I appreciate the advice on the TransGo shift kit, it really seems to work well with the Sonnax servo.
One more question for you guys. This C6 is behind a 351M engine and it's missing the inspection cover. Can I get this inspection cover from any engine (windsor) or does it have to come from a Modified engine?
Thanks again for all the help,
Gerald.
11-01-2006, 04:19 PM   #9 (permalink)
clevelandstyle
Any cover should work.
11-02-2006, 11:17 AM   #10 (permalink)
boullestergm
Guys, I measured the bolt hole spacing on the bell and came up with 10" from hole centerline to centerline. I looked at a C6 cover from a 351W and it only had 9" from hole to hole.
Does anyone have a C6 cover with the 10" spacing that they would sell?
Thanks,
Gerald.
