There have been from time to time questions about building a manual valve body at home. Well I built a reverse manual at home it was a lot of fun. From my experence I would never try it again. It only cost about $10 to do, but it took about eight hours including the planing. My sugestion to anyone wanting to try it SPEND THE $200 ON A PA. You could also buy the kit from Jay if you must do it yourself. JMHO
P.S. don't bother asking me how to do it cause I won't tell you. I wouldn't want to put anyone through what is involved.[img]/forums/images/smiles/icon_frown.gif[/img]
<font size=-1>[ This Message was edited by: Freddie on 10/25/06 10:28am ]</font>
then why did you bring it up then[img]/forums/images/smiles/icon_bicker.gif[/img][img]/forums/images/smiles/icon_bs.gif[/img][img]/forums/images/smiles/icon_lame.gif[/img]
That looks very much like a copy of a popular brand VB. What about mods to i think it's the valve beside the pressure reg valve which is plugged off? Also there is a hole drilled through the top of the upper valve body in the lower area beside the blue dot. What other mods other than the cutouts?
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>I'd guess no engine braking in 1st?
Thanks for posting pics, now I can check and odd VB I've in my parts bin.
I just did a Jays kit. Cost $75 and took me all of 20 minutes to mill the 4 channels that needed cut. Shifts very firm although I went a bit overboard on the optional pressure relief washers and ended up with 300+ lbs of line pressure so I'll have to drop the pan and remove the washers to get the line pressure down before I do much dragstrip flogging. Cant race till april anyway.. I would and will use one of his kitd again.Simple and well thought out and no 2-3 flare .
Anyway to make a Manual Reverse with engine braking in 1st?
Anyone? (thanks)
On 2006-10-31 00:12, mikeandnatasha wrote:
I went a bit overboard on the optional pressure relief washers and ended up with 300+ lbs of line pressure so I'll have to drop the pan and remove the washers to get the line pressure down before I do much dragstrip flogging. </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>Have more info or a link I missed while searching? Thanks!
<font size=-1>[ This Message was edited by: MisterN on 11/1/06 8:29am ]</font>
