11-19-2006, 05:05 AM   #11 (permalink)
PaulS1950
Best Core to start with?
Good choice! Now all you need is a good stock overhaul kit, a TransGo -2 kit, a 72 or later valve body, a big transmission cooler, C4 converter and a bell housing to match. The standard parts are easily good for 400 HP so you have no worries.
Paul
11-19-2006, 07:06 AM   #12 (permalink)
64 TBOLT
it came off a V6. is it a lockup one?? youll be able to tell when you pull the pan
11-19-2006, 08:22 AM   #13 (permalink)
MisterN
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>If it is, any the converter worked... I coulding find a converter so it might be a part someone else wants. Don't junk the converter right away, if it'a lockup type.
MisterN is offline   Reply With Quote
11-19-2006, 09:05 AM   #14 (permalink)
tcgrmt
How do I tell if it's a lockup convertor?
Do I need to dig it out of the garage trash?
tcgrmt is offline   Reply With Quote
11-19-2006, 09:29 AM   #15 (permalink)
64 TBOLT
did you pull the pan??? hang on to the converter for now
<font size=-1>[ This Message was edited by: 64 TBOLT on 11/19/06 11:29pm ]</font>
11-19-2006, 12:17 PM   #16 (permalink)
mikeandnatasha
Paul
'70 and up will work for a valve body. Ive got a few extra and a 157 tooth bell if you need one
mikeandnatasha is offline   Reply With Quote
11-19-2006, 01:35 PM   #17 (permalink)
64 TBOLT
may not need a VB. gotta pull the pan and look
11-19-2006, 02:24 PM   #18 (permalink)
mikeandnatasha
If its got a deep pan it will be a lockup converter valve body
11-19-2006, 03:13 PM   #19 (permalink)
tcgrmt
Yeah I tore it down today. I didn't pull the clutch packs apart but all the thrust washers look really good. Cleaned the case and tail.
My front plant has a roller bearing on the tail shaft side that doesn't seem to be removable. Is that typical?
My trans has a deep pan (vs. the C4 pan) like the pictures on this site, I thought all C5's had the deep pan or are there two deep styles of pans?
11-19-2006, 03:31 PM   #20 (permalink)
64 TBOLT
which VB does it have
