06-27-2007, 10:03 PM   #1 (permalink)
myles860
C4 Servo
Hi
New here so bear with me please. Last weekend I I replaced teh servo gasket on my car didnt change anything but when i was puting it back in I heard this pop. I pulled it back out and everything looked okay but now I dont have third gear. Any idea what I broke?
myles860 is offline   Reply With Quote
06-28-2007, 01:03 AM   #2 (permalink)
gregaust
Re: C4 Servo
Pretty sure you'll find it is 2nd gear you don't have. Did you remove the valvebody to fit the servo.If not the strut that applies the band has dropped out.
06-29-2007, 09:12 PM   #3 (permalink)
PaulS1950
Re: C4 Servo
Gregaust knows his C4's - I agree that you probably dropped a strut. You can repair it by dropping the pan and valve body, putting the strut back in place, install the valve body and pan. Then readjust your bands and drive off into the sunset.
Paul
\"R\" servo Scatback C4 Transmissions 7 10-28-2007 10:56 PM
C4-C6 servo\'s BUCKETOBOLTS C4 Transmissions 8 11-15-2006 02:35 PM
C4/C5 servo 64 TBOLT C4 Transmissions 0 08-03-2004 06:09 PM
A or H servo for C5 papadaddy C4 Transmissions 11 04-12-2004 09:44 PM
C4 "Z" servo? frankenfords All Ford Techboard 3 02-15-2003 10:02 PM
