09-23-2007, 06:00 PM   #1 (permalink)
MisterN
Another leak: how to stop a maunal control lever leak?
On my second O-ring, and it's still leaking. All the parts look good, but she still drips out the lever.
Any suggestions?
MisterN is offline   Reply With Quote
09-23-2007, 07:58 PM   #2 (permalink)
gregaust
Re: Another leak: how to stop a maunal control lever leak?
Is it just an o'ring ? There is a special square type seal for there
09-23-2007, 08:57 PM   #3 (permalink)
MisterN
YEah, just under the 1/2 nut. Rebuild kit came with a replacement one.
Not this tranny, but where the nut is missing, goes the o-ring.
However not that I think about it, it might be the larger lever...
09-24-2007, 02:09 AM   #4 (permalink)
gregaust
Yes that seal to go in there ,is not an o'ring ,it is a special square section seal.. I don't mean the selector seal in the case.
09-25-2007, 12:48 AM   #5 (permalink)
PaulS1950
I use a "quad ring" on the small shaft. The cross section looks like it is four o-rings glued together or a cloverleaf. That means it has twice the sealing surfaces and higher pressures in the area of contact.
Paul
09-25-2007, 02:56 AM   #6 (permalink)
gregaust
Yes that's the one..
09-25-2007, 04:51 PM   #7 (permalink)
MisterN
Thanks Greg and Paul! I'll have to go double check my rebuild kit....
10-03-2007, 08:52 PM   #8 (permalink)
MisterN
Can someone snap a picture of this seal?
Have a part number?
All I see are o-rings... #6 in pic.
10-03-2007, 11:24 PM   #9 (permalink)
PaulS1950
Number six is an o-ring but there is a quad ring in most kits that will fit a slightly worn shaft and bore well enough to keep it from leaking.
Paul
Cant get rig of the oil leak mdula All Ford Techboard 34 07-23-2007 06:51 AM
What would cause this leak 66GreenMustang C4 Transmissions 4 12-07-2006 12:52 AM
Radiator Stop Leak for MikeMustang FEandGoingBroke All Ford Techboard 0 10-21-2004 12:53 PM
I got a leak NoLongerHere2 The Garage 6 08-12-2004 02:33 PM
Is "Stop Leak" Snake Oil? HankyJ All Ford Techboard 3 10-14-2002 08:55 PM
