09-25-2007, 08:28 PM   #1 (permalink)
chamucomeza
C4 Transbrake
i`m instaling a valve body with transbrake,but didn`t work, do i have to do something to the case or just install the valve body and conect the 12volts cable.
chamucomeza is offline   Reply With Quote
09-26-2007, 03:11 AM   #2 (permalink)
Mario428
Re: C4 Transbrake
Who's transbrake are you installing? Is it an internal or external solenoid?
My Performance Automatic I just ran the connector thru the modulator hole and supply 12 volts when I want the tranny brake to engage.
[IMG]http://img.photobucket.com/albums/v660/Mario428/T-BirdBurnoutsmall.jpg[/IMG]
09-26-2007, 12:29 PM   #3 (permalink)
chamucomeza
Re: C4 Transbrake
thats what i did, it is internal solenoid ,i believe that when you shift to reverse it does not have the to work the reverse until you turn on the transbrake is this true because mine does work whit the transbrake of. when i shift forward turn on the transbrake and it is the same.
C-6 TRANSBRAKE ? torino501 All Ford Techboard 3 09-29-2007 09:54 PM
transbrake rbizz C4 Transmissions 7 02-17-2006 05:59 AM
DIY transbrake? etcetera C4 Transmissions 1 01-12-2006 10:07 PM
c4 transbrake flynsolo All Ford Techboard 1 01-15-2003 07:12 AM
C4/transbrake ? myoldidisbroke All Ford Techboard 0 02-10-2002 02:05 AM
Holley
