02-09-2008, 09:33 AM   #1 (permalink)
umc2762
Vacuum Modulator-Simple Question
I have a '76 Bronco 302 with a C4. I am replacing modulator valve on transmission and the Ford dealer has 3 color codes listed. He says I must match up color to the old one to get correct replacement. Of course after 30 years there is no color left on the old one. Autozone lists black stripe type which doesn't work properly.
Does anyone know correct color code for this Bronco.
Thanks.
umc2762 is offline   Reply With Quote
02-09-2008, 12:57 PM   #2 (permalink)
Re: Vacuum Modulator-Simple Question
If there is a blue stripe get it.. If it's pink, get that one... Then try all 3
You are going to have to call ford adn ask them the diffrent values on teh 3 diffrent modules.
There HAS to be a reason there were 3 diffrent types, most of the reason will be load caried by the vehicle and shift needs, at least that's what I think...
FE
Honor!
02-09-2008, 06:18 PM   #3 (permalink)
umc2762
I tried the black stripe from Autozone and the shifting was not normal. Much higher rpms to shift from 1st to 2nd and slightest touch of accelerator would cause downshift from 3rd to 2nd. at all speeds.
Called several parts stores, another Ford dealer, and finally a transmission shop and got different answers from all of them. Trans tech said black stripe is for diesels and heavy duty use. I have most faith in him - he said to get a green stripe but I thought I would check to be sure.
Rock Auto lists about 5 different colors all for 76 Bronco.
Exchanged the black stripe for the green this morning and installed it. Working perfectly just like the original.
Autozone part # MV209 or MV317 - green stripe $9.99.
02-09-2008, 09:19 PM   #4 (permalink)
KULTULZ
FYI-
Component useage such as this is listed in a companion book to the FORD SHOP MANUAL called Specifications. That book will give you information such as this.
[FONT=Century Gothic][/FONT]
02-10-2008, 12:37 AM   #5 (permalink)
gregaust
The green or yellow is what i use.. White for the screw in ones . The green i find gives a little later shifts how i like them .. I dont even have a listing on the black
02-10-2008, 08:53 PM   #6 (permalink)
PaulS1950
I use the green stripe on my rebuilds. I have for as long as I have been building them (1970). If you don't want the late shifts use the 1.5" rod instead of the 1.6"
Paul's Street and Strip
Performance AODs & C4s
paulstephens@q.com
6522 51 Ave. S.
Seattle, WA. 98118
206.725.0881
c6 vacuum modulator elsanyo All Ford Techboard 3 05-03-2005 10:24 PM
vacuum modulator valve 69falcon69 C4 Transmissions 2 02-26-2004 06:18 AM
vacuum modulator etp20 Galaxie Pages 1 01-23-2004 11:17 PM
vacuum modulator gchero351 C4 Transmissions 1 12-07-2003 12:09 AM
Vacuum modulator adjustment 1967galaxie C4 Transmissions 0 10-20-2003 05:47 PM
