Re: Converter flush-out
If you have had any volume of foreign material go through your converter you need to replace it. There are one-way clutches and thrust washers in your converter that wear when abrasive (clutch) material goes through it under normal working conditions. Getting the stuff out of the converter just isn't good enough to be sure it will hold up. If your converter has drain plugs in it you can flush it using a pump and hose with 1/8" pipe nipples but you can't replace the worn parts without cutting it open, replacing the worn parts and welding it all back together again. (when you weld it you have to be sure that no weld flashing or metal gets into the converter - most of the "rebuilt" converters that I have seen in my area have welding residue in them. I recommend you buy new parts - not "rebuilt". Some people have good luck - if that's you then flush your converter and use it. If you are like me and a bit on the unlucky side when trying to keep costs down then get a new one.
Paul
