02-27-2008, 12:30 AM   #1 (permalink)
torkair
Bell housings
I think I've found an FMX with a big block bell attached to it at one of the local junk yards. Now providing I'm right, will I have any trouble bolting it on to a C4? I want to swap the 302 in my 72 Gran Torino out for a 400 without too much in the headache department so any and all advice would be very helpful.
Thanks in advance!
torkair is offline   Reply With Quote
02-27-2008, 01:17 AM   #2 (permalink)
gregaust
Re: Bell housings
Sorry mate won't work.. The FMX bell is way different to C4....
02-27-2008, 02:19 PM   #3 (permalink)
ckelly
Re: Bell housings
You need to look for a C4 in a 77-78 T-bird or other big car with a 351M.
02-27-2008, 03:17 PM   #4 (permalink)
torkair
Re: Bell housings
I'll make sure to double check it against the other trannies that they have there.
02-29-2008, 12:16 AM   #5 (permalink)
mmerlinn
Re: Bell housings
FMX bell is attached to the transmission with 4 bolts.
C4s use 7 if attached using the pump bolts or 5 bolts otherwise.
There is only one big block bell that fits a C4, and it will ONLY bolt to a C4 with the dipstick in the pan. It will not bolt to a C4 having a dipstick in the case.
mmerlinn (http://mmerlinn.com) -- "Careless and sloppy writers are usually also careless and sloppy at thinking. Answering questions for careless and sloppy thinkers is not rewarding." - Eric Raymond
mmerlinn is offline   Reply With Quote
02-29-2008, 01:50 AM   #6 (permalink)
gregaust
Re: Bell housings
Unless you go to an aftermarket BB to C4 bell they fit on the pump bolts on any C4 case.
C4 bell housings? fairlaneguy All Ford Techboard 6 05-25-2008 07:22 PM
bell housings gator72106 C4 Transmissions 4 01-25-2007 09:04 PM
interchangable bell housings torino460gt Torino Pages 8 12-25-2006 09:09 AM
Bell housings coolfalcon C4 Transmissions 2 08-25-2005 05:27 PM
change bell housings on c4 trans? fastranger All Ford Techboard 4 06-15-2005 04:06 AM
Lakewood
