Re: Stopping leak at Vacuum modulator C4 Tranny
Well, I THOUGHT that worked (may still have, and perhaps I have another small leak). I took the VM out.. inspected the area around the mounting point.. All looked fine. Put gasket maker on and reinstalled.. Woila.. seemed to work. Car sat still all through dinner etc with no leak.. normally leaks a small amount by that point. Drove it a bit, pulled into garage and now have a small spot again. Aggrivating!!!! Could be another spot, but I'll be damned if I can find it. Replaced both front and rear seals about two months ago, replaced pan gasket, new cooling lines (no leak there). Will see in the AM.
Fingers crossed
Mike
