06-21-2008, 06:46 PM   #41 (permalink)
forthman
Re: C4 won't shift into 3rd gear when cold
Glad you got it atleast back to working warm.
You did say there was a B&M shift kit in it. Maybe it was making more pressure than the TCI.
In any case i would give TCI a call and tell them about your wimpy valve body. ( maybe talk them into a manual )
I am with Paul i bet your seals are worn or hard.
It should get you thru the summer if it will still bark the tires.
Might try some lucas tranny treatment.
It has worked great for me on old hard seals.
Had a buddy with a 93 vert AOD that sat for 3 yrs. When he started it finally it would not shift at all. I added the Lucas in it and when it warmed up he drove it off.
Won't last forever.........
1966 Stang Coupe Org. 6 cyl. 351w,Sealed Power Hypers, ARP bolts,Total Seal rings,Eagle H-beams rods,Balanced,Hedman long tubes, Pro Comp 2.05/1.60 Heads, Shaft roller Rockers, Victor Jr intake, Holley 750 DP, Ed Nix Custom .600/.600 254/258 @.050 Solid Cam, Crane solid roller lifters,Richmond 4.11, Strange mini spool, Modified C4, 3500 stall, Redneck Transbrake, B&M Hammer shifter, Shelby lowered, Pro Comp 6Al system. Mickey Thompson 275/50 Et Street Drag radials.
AOD will not shift out of first gear SlowFord All Ford Techboard 8 05-19-2008 01:32 AM
No third gear or doesnt want to shift to it. sniper626 C4 Transmissions 2 08-30-2007 12:10 AM
Do all FMX transmissions slip the 2-3 shift in cold weather until warmed up? adgdghr123 All Ford Techboard 6 11-17-2004 10:25 PM
Cold Shift 1967galaxie C4 Transmissions 2 11-27-2003 10:19 PM
C-6, won't shift out of first gear argonaut All Ford Techboard 2 08-03-2002 08:29 PM
