Re: What sealer do you guys recommend?
I have tried nearly all the sealers there are and I have found the best and worst sealers for each application. Trannys should NEVER have silicone RTV on them - even if you get the case clean enough to get the RTV to bond, you can never get all of the RTV off without sanding. Most transmission fluids will disolve the silicone sealers and it ends up in one or more passages. RTV works well for water but so does Gasket Maker - and the gasket maker is so much easier to clean that I use it for everything but head and exhaust manifold gaskets. Silver chrome paint works best for head gaskets (tes, even the imprinted ones), and a good metal to metal contact works best on exhaust manifolds. Headers won't seal this way unless the flanges are at least 3/8" thick.
Paul
