04-23-2008, 12:24 PM   #1 (permalink)
jasper351
C4 pump swap
Hi, I was just wondering are C4 pumps interchangeable throughout the years? If not, what are the differences and how do you determine what will work? Thanks for the help. Craig
jasper351 is offline   Reply With Quote
04-23-2008, 04:16 PM   #2 (permalink)
mmerlinn
Re: C4 pump swap
FD C4F Catalog: PUMP ASSEMBLY, Main
Basically, you have 64-66 using small input and o-ring seal, 67-69 using small input and gasket; and 70 up using large input. As long as you stay within those groups they all interchange.
mmerlinn (http://mmerlinn.com) -- "Careless and sloppy writers are usually also careless and sloppy at thinking. Answering questions for careless and sloppy thinkers is not rewarding." - Eric Raymond
mmerlinn is offline   Reply With Quote
04-23-2008, 06:17 PM   #3 (permalink)
gregaust
Re: C4 pump swap
Yes but what about the actual pump body? The input shaft differences etc can be changed by removing/unbolting the stator support.
I have looked and seems the 66-69 pump bodies are the same as 70+ but not 100% sure
04-24-2008, 09:34 AM   #4 (permalink)
mmerlinn
Re: C4 pump swap
FD C4F Catalog: PUMP BODY, +Gears
Even though there are 3 different casting numbers, I believe all you need to worry about is whether a gasket (67-86) or o-ring seal (64-66) is needed.
04-24-2008, 08:31 PM   #5 (permalink)
gregaust
Re: C4 pump swap
Ok sounds good . Other tah nth o'ring type all others are same.
One thing i have noticed though is the EO castings i've had have no converter pressure relief (valve with little pushin clip) valve in them. Doesn't seem to make any difference though.
62 gal power steering pump swap? cole Galaxie Pages 0 04-15-2008 03:51 AM
power steering pump w/swap? vintagespeed Galaxie Pages 4 11-12-2007 10:15 PM
HOW EASY: Can you swap an OIL PUMP when the engine is installed? 67fastback Late Model EFI Techboard 13 03-19-2007 03:06 AM
Water Pump Swap 6mustang8 All Ford Techboard 8 04-29-2004 03:46 PM
70 torino pwr steering pump swap question... kc429scj Torino Pages 0 11-22-2002 12:58 AM
