04-30-2008, 04:57 PM   #1 (permalink)
chunger
Convert Green Dot to regular C4?
So, the differences between the "Green Dot" early trannies and the later c-4's have been discussed extensively on this board. Mainly, the difference is the valve bodies, right?
What I'm curious about though, is can a 1967 Green dot c-4 be converted to a later (say 68-69 C-4) by changing the valve body?
Thanks!
-chunger
chunger is offline   Reply With Quote
04-30-2008, 09:36 PM   #2 (permalink)
gregaust
Re: Convert Green Dot to regular C4?
Yes it can ,just swap the valvebody and possibly shifter to suit.
05-01-2008, 09:02 AM   #3 (permalink)
chunger
Great! Thanks.
05-01-2008, 10:15 AM   #4 (permalink)
Just Jim
If it is a 1967 it's not a "green dot " anyway. The '64-'66 C4 was a green dot and be converted to the better shift pattern by swapping in a '67-'69 valve body. See if your valve body has any identifing marks beginning with C7 or C8 or C9. If so it's not a green dot.
\'58 Morris Minor 289 S/S MM
is synthetic oil better than regular? andysam All Ford Techboard 18 01-24-2008 07:51 AM
regular 5.0s and mass air fordltdpolice All Ford Techboard 4 12-26-2006 03:14 PM
Regular or unleaded? pasvorto Galaxie Pages 8 06-15-2004 08:32 AM
Synthetic or regular? JAhrens All Ford Techboard 0 06-13-2003 04:56 AM
RPM Air-Gap vs. Regular RPM Bamm-Bamm All Ford Techboard 4 05-03-2002 05:51 AM
