05-06-2008, 10:42 AM   #1 (permalink)
capricol
lost forward gears!
Hi everyone, rebuilt my c4 a few months ago using a lot of advise from this forum.Did some oiling mods, kolene steels, kevlar bands, pa servo, hughes full manual valve body etc.Was very carefull with clutch pack clearances and used the Haynes book as well as this forum for the build up. Has been working great on the street, but on my first pass up the strip yesterday, by the time i got to the end of the quartermile i had lost all forward gears. I still have reverse, but thats all. Still managed a 12 @110 though!! Any ideas greatfully received before i take the trans out. Thanks in advance.
capricol is offline   Reply With Quote
05-06-2008, 04:14 PM   #2 (permalink)
gregaust
Re: lost forward gears!
Will be an issue with the forward clutch.. Maybe broken belleville spring?
05-06-2008, 07:21 PM   #3 (permalink)
clevelandstyle
I concur.
Grabber Green \'70 Mach I 351C 4V 12.32 at 111mph
Robin Egg Blue \'79 Fairmont 408C 4V 10.50 at 127mph
05-07-2008, 09:43 AM   #4 (permalink)
capricol
[Greg, just stripped the trans and all looks pretty good, except the five bolts connecting the stator support to the pump had all backed off about 2/3 turns!! Do you reckon this could have been the problem, i had to rev it pretty good to get reverse so i could back it in to the garage, but no forward gears at all of course.
05-07-2008, 10:01 AM   #5 (permalink)
Mario428
Serious pressure loss there, definitly the problem, relatively an easy fix luckily.
Need all the info to diagnose a problem, poor reverse does change it.
Hopefully your cluches and stuff are fine and you can reassemble. Take a good look at you sealing rings in case they got damaged flopping around.
[IMG]http://img.photobucket.com/albums/v660/Mario428/T-BirdBurnoutsmall.jpg[/IMG]
No forward gears torkair All Ford Techboard 5 03-03-2008 01:04 PM
No forward gears, harsh reverse ksilvy C4 Transmissions 3 08-20-2007 01:24 PM
Need C5 help forward gears slipping reverse ok. cpunet C4 Transmissions 1 09-19-2004 02:39 PM
Lost all forward gears on my race C4/C5 tranny 1970coupe C4 Transmissions 4 08-20-2004 10:50 AM
Lost all forward gears in my race C4/C5 tranny 1970coupe All Ford Techboard 0 08-09-2004 10:53 AM
