05-11-2008, 05:30 PM   #1 (permalink)
meagain
C4 trans #0A169485 what is it
pick up a c4 trans the number on the case is 0A169485 does anyone know what it is and came out of thanks MIke
meagain is offline   Reply With Quote
05-12-2008, 12:59 AM   #2 (permalink)
PaulS1950
Re: C4 trans #0A169485 what is it
Meagain,
I returned your PM.
For others, if your C4 has a tag bolted to the servo cover the numbers on it is the best way to identify the transmission. if that fails the next best way is the date code by the shift lever in conjuction with the stamped part number at the top rear of the case. If you can't find that then the letter on the front servo (BIG cast-in letter) and the diameter or number of splines on the input shaft. The location of the vent will tell if it is before 71 or after so that can help.
If you can get some real close pics it helps too.
Paul
05-12-2008, 05:03 PM   #3 (permalink)
mmerlinn
That is the last 8 digits of the VIN of the vehicle that it was originally in. Unless you have a list of all of the VINs Ford used, that number is essentially worthless beyond POSSIBLY pointing to the vehicle year.
As Paul said, tag numbers are the be all and end all of Ford IDs.
mmerlinn (http://mmerlinn.com) -- "Careless and sloppy writers are usually also careless and sloppy at thinking. Answering questions for careless and sloppy thinkers is not rewarding." - Eric Raymond
mmerlinn is offline   Reply With Quote
05-12-2008, 07:56 PM   #4 (permalink)
meagain
thanks everyone, this ford stuff is new to me, at least I know it's a C4 and the price was right, I have access to tracking down the owner, he's out of town, but should return soon. again thanks, it's nice to know there's good people out there who don't mind helping a guy out.
05-13-2008, 01:16 PM   #5 (permalink)
meagain
Well I started cleaning this trans today, and found the tag, here's the # PEE V1 DOOPD M4. So what do I have, thanks Mike
05-13-2008, 11:38 PM   #6 (permalink)
mmerlinn
I did a google search and found the info. Remember that Google is your friend when you want to know something.
05-14-2008, 10:47 AM   #7 (permalink)
PaulS1950
According to the code you havs a 69 C4 but according to the shaft you have a 70 C4. It is a dual range C4 from a 302 2bbl.
It will work fine in your application - I sent the recommended mods in PM
That one is a keeper!
Paul
Lakewood
