05-16-2008, 02:45 PM   #1 (permalink)
MY TWO STANGS
BROADER Performance C4 big block race trans
I have been looking for a new trans for my drag Race car and the Broader trans looks good to me . Could any body tell me if these transmission s can be built with a 6 pinion planitary . We have had some failers and would like the 6 pinion set up .
05-16-2008, 07:58 PM   #2 (permalink)
1badasslx
Re: BROADER Performance C4 big block race trans
yes they sure can.. you can buy them and install them your self,
96 stang
5.0 - c4
1badasslx is offline   Reply With Quote
05-16-2008, 08:20 PM   #3 (permalink)
notched306
i like there stuff.i have a forward manual valeve body in my c4 and works awsome.i know you said trannys but wanted to give my .2 on there products
turbo notch,fully built 306 by yours trully,running on E85
notched306 is offline   Reply With Quote
05-17-2008, 11:06 AM   #4 (permalink)
PSIG
...Could any body tell me if these transmission s can be built with a 6 pinion planitary . We have had some failers and would like the 6 pinion set up .
As I understand it, the 3-pinion has plenty of strength, except the individual pinion (planet gear) thrust washers fail under high horsepower thrust loads. This is apparently why the factory went to double thrusts in the C5. The needle bearing upgrade (under the pinion planet gears - not just the body) in the Broader 3-pinion allows it able to handle the higher HP. Have you talked to him about it? (817) 599-9400 I'd be curious to hear what he tells you.
David
05-17-2008, 02:56 PM   #5 (permalink)
MY TWO STANGS
I was running a C5 with a Hughes race kit with manual valve body when I broke two planet Gears behind my 308 inch engine .this is why I was looking for something better to run with my stoker . BROADER was not open so i will contact them on Tuesday to see what HE says. thank for your help .
Tranny killing 1/4 mi time ?/Broader performance tranny 10secgoal C4 Transmissions 12 04-18-2004 03:22 PM
Broader Performance cmf60 C4 Transmissions 1 02-08-2004 03:04 AM
FW: Free transmission from Broader Performance custom300fe The Garage 0 12-23-2003 09:04 AM
General question about performance c4 trans Matt All Ford Techboard 10 01-15-2003 12:11 PM
FMX trans? Any Good for Performance??? BFXcomet All Ford Techboard 6 04-10-2002 12:51 AM
