05-18-2008, 09:48 AM   #1 (permalink)
sthomp29
Automatic Kickdown????
I swapping a c4 for a rebuilt c6 in my 70 torino. Anyways, my big question is this... I have a Holley 650 DP that is not normally recommended for ford's unless you install a lokar or similar kickdown kit. I want to keep the 650 DP due to the fact of running NOS and a better overall carb.
So, do I keep the 650 DP and install the kickdown (how difficult is the install?), or do I go back to Summit and excahnge for the cheaper 750 due to having the kickdown installed?
Please advise, I probably already answered my own question, but need some direction since my motor is due back from the machiners tomorrow.
sthomp29 is offline   Reply With Quote
05-18-2008, 09:54 AM   #2 (permalink)
69fury
Re: Automatic Kickdown????
just a plate that bolts onto the throttle likage. no biggee
69fury is offline   Reply With Quote
05-18-2008, 02:42 PM   #3 (permalink)
gregaust
Yes there are some kits that might bolt on to give that carb a Kickdown link depends on exact model you have or as you know a cable setup.
05-19-2008, 12:54 AM   #4 (permalink)
PaulS1950
Holley makes a Ford kick-down linkage for the carb. Then all you need is the rod from the wrecking yard or pull a part.
If you are capable you can make one.
The only critical length is that you have .060" gap between the carb lever and the adjustment screw with wide open throttle and the kick-down fully depressed.
Paul
05-21-2008, 08:53 PM   #5 (permalink)
sthomp29
Thank bud, I think I may go the Holley or Lokar route. Fabbing is a non-issue. I just know the 650 DP will give me more gain in the long run.
Thanks fellas!
C4 Kickdown rod dwells C4 Transmissions 5 04-02-2008 02:20 AM
Kickdown Rod Help Freddie C4 Transmissions 1 09-07-2006 09:24 PM
c4 kickdown stroked393w C4 Transmissions 3 03-25-2006 05:34 PM
Why isn\'t Kickdown Necessary? 79stang351w C4 Transmissions 2 05-26-2005 11:53 PM
FMX Kickdown rod poochigambino All Ford Techboard 3 02-02-2004 07:09 AM
