05-18-2008, 04:31 PM   #1 (permalink)
bigd2000
Help C4 Problem
Hello, new to forum and ford automatics. Just purchased a mustang with C4 trans. With the shifter in drive it shifts great other than the early up shifts. Try to shift manually and the problem begins. When I go to 2nd it feels like nuetral. Engine revs to about 4000rpm then its like popping a clutch in 5 speed. Let the rpm fall below 4000 and its like nuetral again. Upshift to 3 and its normal again. Under WOT manual shifting works great and definately not sluggish.Thanks for the help in advance.
bigd2000 is offline   Reply With Quote
05-19-2008, 12:58 AM   #2 (permalink)
PaulS1950
Re: Help C4 Problem
Can you find out what kit was installed (if it was a kit) or what mods were made to the valve body?
It sounds like there is a problem in manual selection of the gears. if it shifts ok in drive then drive it there and when racing you can shift manually. It's not a fix but it does by-pass the problem until you can sort it out.
Paul
New kid on the block and already got a problem. (Headliner) UPDATE: Problem solved Dave66Galaxie Galaxie Pages 13 09-24-2006 11:51 AM
C4 problem badbird All Ford Techboard 5 08-18-2006 04:27 PM
Could this be a problem? 67falconer All Ford Techboard 11 08-09-2006 08:57 AM
T-5 Problem? FFR65MKIII Mustang Pages (1979-1995) 3 03-17-2006 09:09 PM
T5 problem pendragon All Ford Techboard 4 12-30-2005 05:20 AM
Holley
