05-20-2008, 04:23 AM   #1 (permalink)
dragracerdave
Trans fluid level?
Is there any problem with having too much fluid in the trans? did a trans swop this weekend & after filling & road testing the car, it seemed to have too much fluid in it, Drained some out (thank heavens for drain plugs!) but after driving the car home (approx 50 miles) & dipping the trans again It seems theres a little too much fluid still, should I drain more out or is it ok to leave? Its just above the 'don't fill' mark on the dip stick btw.
Cheers, Dave.
[IMG]http://i120.photobucket.com/albums/o192/dragracerdave/Hobby%20Horse/2muchavahh.jpg[/IMG]
Street Driven Bracket Racer
dragracerdave is offline   Reply With Quote
05-20-2008, 04:08 PM   #2 (permalink)
gregaust
Re: Trans fluid level?
If it is just above , no real big problem. It's if oil level is high enough that the spinning interals churn up the oil will cause issues.
05-20-2008, 04:46 PM   #3 (permalink)
Ususally the dip stick full level is a goodly distance below the rotating parts. You'll be fine.
05-23-2008, 04:27 AM   #4 (permalink)
dragracerdave
Thanks guys, I took the car out last night & I can't believe how much for wicked it feels with the new trans/convertor! going to the track this weekend! hope its dry!
05-23-2008, 05:17 AM   #5 (permalink)
gregaust
Good luck for the weekend mate..
C-4 Transmission fluid level question norcal500 C4 Transmissions 4 05-23-2005 03:30 PM
8.8 differential fluid level dtitus All Ford Techboard 0 04-21-2005 08:40 PM
FMX 3000 stall / Fluid level sic071 All Ford Techboard 3 08-11-2004 12:34 AM
Correct c4 fluid level? 79Fairlane C4 Transmissions 5 10-29-2003 04:59 PM
C4 fluid level dragman64 All Ford Techboard 3 04-04-2002 06:43 PM
