Re: will it be enough
350 hp yes, IF the kit contains the parts to put in five clutches where there are four and IF the cooler is a BIG one.
Coolers are rated in lbs of towing weight so get one rated at 33000 lbs at a minimum. And IF your engine is naturally aspirated.
Paul
