Harsh shift 1 to 2 and "clunk" getting in gear?
I have searched and I think I have some ideas, but before I drag it back to the tranny shop, I am hopeing to get you folks opinions as well.
From park into R there a pretty good jolt/clunk coming from the tranny. The 9" rear was also went through in the process. Unless they screwed it up, the lash should be OK. Then there is the same jolt coming out of neutral into D.
And then from 1st to second, the shift is pretty stiff too. From 2nd to 3rd its softer, bout right IMHO.
I am running Supershift Amsoil ATF which they spec for Type F. Amsoil says it will tighten shifts. If 2nd to 3rd were tight as well, I think I would just assume that its my oil and forgetaboutit.
But I have never driven a C4 before, so I am worried. Do harsh shifts lessen the life of the tranny? I chose the synthetic amsoil becuase I want maximal life out of the oil, not because I race or tow much.
Could the bands be out of adjustment? Or just my agressive oil choice?
This a used tranny, but I had it freshened up -- the shop said they replaced all the seals and couple of clutches (everything that looked bad at all). It was newly rebuilt less than 5k miles before the prior vehicle (302 Mustang) was wrecked. Then it sat for 5 years in a garage till I traded for it.
It has a stock 12" convertor on it, which if I understand things, has a low stall speed. I have the truck idle set at about 900 - 1000 RPM. I backed off the idle speed and it didn't make much different though, and it became doggy from a standstill during "casual" driving, which is what I mostly do.
1965 F100 240 C4 Autolite 1101, Pertronix Ignitor II
