06-03-2008, 09:26 AM   #1 (permalink)
whenindoubt
C4 Transmission not shifting down
I just installed a newly rebuilt C4 transmision in my 66 mustang and it is not shifting properly. When i put it in reverse it works fine, then the drive position it will shift up through the gears but you can not feel the shift. I am running open headers rigt now so its loud and hearing the shift is hard but i have had it up to 70 with very little gas pedal and low rpms so I assume its making it to third. When coasting for a while say uphill it should drop down to 2nd but seems to be in third. Get a rpm increase with no thrust. If i oull off the road and stop it seems to stay in 2nd. I can manually shift it just fine. I have checked the vaccum pressure at the modulator it is about 10-12 the pin in front of the modulator is 41mm long or 1.614 inches. this is the push in type modulator. I was told to screw the modulator adjustor all the way in and half a turn out , and it did seem to help a bit. Any other ideas out there???? Is the pin long enough??
whenindoubt is offline   Reply With Quote
06-03-2008, 11:53 PM   #2 (permalink)
PaulS1950
Re: C4 Transmission not shifting down
Answered in the C4 forum.
Paul
c4 transmission braking when shifting into 3rd prodigy200424 C4 Transmissions 5 04-07-2006 08:59 AM
Transmission not down shifting. earlybronco42 C4 Transmissions 1 05-23-2005 01:29 PM
C4 Not Shifting 1-2 bmfouts65 C4 Transmissions 0 05-09-2005 10:58 PM
Shifting it! polkat C4 Transmissions 2 05-17-2003 09:59 PM
Shifting knifeman85 All Ford Techboard 2 05-12-2003 02:56 PM
