06-04-2008, 02:41 PM   #1 (permalink)
Sponge
Manual Trans: Powershifting, could you explain?
Hi all,
What do you mean by "powershifting"? I see this word many times and to sleep correctly the rest of my lisfe , I'd like to know what is it exactly.
Dylan
06-04-2008, 02:45 PM   #2 (permalink)
ckelly
Re: Manual Trans: Powershifting, could you explain?
You shift gears with your right foot planted firmly on the floor. It helps to have A) quick reflexes and hand/foot coordination B) a spare tranny and C) a rev limiter
06-04-2008, 02:49 PM   #3 (permalink)
Sponge
Thanks dude, now I can go sleeping, it's around 23.50PM and I'm tired.
06-09-2008, 02:39 PM   #4 (permalink)
1badasslx
a auto matic is faster....
96 stang
5.0 - c4
1badasslx is offline   Reply With Quote
06-09-2008, 06:38 PM   #5 (permalink)
MY TWO STANGS
Only if you can't drive a standard ! I switched my car from Standard to AUTO and lost 2 tenths . Both my 60 foot and 1/4 mile time was slower . If you are going to run a standard and granny shift then you should run a Auto.
06-10-2008, 04:36 AM   #6 (permalink)
PaulS1950
"Power shifting" is done just as the power curve allows the gears to lose preload as you stabthe clutch pedal and slide off of it. As was stated earlier your right foot holds the pedal to the floor.
Anyone who loses time when switching from a standard to an auto either is a shifting machine or has a poorly prepared combination for the automatic. Your auto 60 foot times should go down and the transmission should shift at least as fast as a powershift in a well prepared auto. The auto will also be much more consistant.
Paul
C4 trans manual rs351capri C4 Transmissions 1 07-11-2007 02:39 PM
Anybody have a 65 with a manual trans? junkyardjeff Galaxie Pages 4 10-13-2005 04:52 AM
Need Help With Manual Trans ID 1970galaxie All Ford Techboard 1 11-02-2003 07:22 PM
Does anybody get to 10s with a manual trans? ville All Ford Techboard 10 04-03-2003 03:28 AM
article on powershifting 67stang351 The Garage 12 03-21-2002 11:05 PM
Probe Industries
