c4 neutral is a forward gear now..
just put my c4 back together, it got new seals, bushings, clutches, bands.. and a park pawl (yes, i broke that) and 3000 stall converter, its in an 84 notch with a 351w... anyways, i didnt open the valve body, its a manual shifting valvebody and shifted GREAT when i tore the transmission down, so i didnt take it apart.. well, now it appears to be in gear when i put it in neutral..reverse works good, it shifts into drive gears but seems to sound like its dragging? i adjusted my bands according to the trusty haynes book... but neutral isnt neutral! i thought i was having trouble adjusting my shifter cable but thats not the case, and i have the linkage inside hooked up right.. reverse is reverse, park is park, and well, it hasnt been off the jackstands.. can my vb have a valve sticking? should i take the vb out and tear it down?
