Re: C-4 Servo Question
JFalcon,
As per your request in the PM I will add my opinion to Greg's. Up to about 450 HP I have found that the "A" servo works well and has a long life with the band. I have never suffered a broken band with the "A" servo and the bands show less than "normal" wear when the pressures are about twenty percent over stock. Since you have a manual vale you have probably got between 30 and 40% more pressure than stock so use what you have. Check with their tech folks to make sure of your pressures. They know their products better than anyone. The valve body mods that I perform have always worked well with "A" servos - as a matter of fact for C4s up to 450 HP I prefer the "A" servo.
Paul
