07-23-2008, 04:29 AM   #1 (permalink)
peterhill
24 vs 26 spline
Gents, currently I have an early c4 24 spline which I am considering reco'ing to heavy duty/ hi-performance specs. I plan to install a blower soon after which will bump the power output to about 400 odd hp. If I'm not drag racing etc and drive sanely will the 24 spline handle the hp or is a 26 spline recommended. The sticky says a 26 can handle 600hp hp so I'm hoping the 24 can handle 400. Thanks. Peter
peterhill is offline   Reply With Quote
07-23-2008, 11:05 AM   #2 (permalink)
forthman
Re: 24 vs 26 spline
No burn outs, no wheel hopping green light take offs.
No power shifting.
It should hold. But if you are going to go through the tranny why not just upgrade it to 26 spline?
1966 Stang Coupe Org. 6 cyl. 351w,Sealed Power Hypers, ARP bolts,Total Seal rings,Eagle H-beams rods,Balanced,Hedman long tubes, Pro Comp 2.05/1.60 Heads, Shaft roller Rockers, Victor Jr intake, Holley 750 DP, Ed Nix Custom .600/.600 254/258 @.050 Solid Cam, Crane solid roller lifters,Richmond 4.11, Strange mini spool, Modified C4, 3500 stall, Redneck Transbrake, B&M Hammer shifter, Shelby lowered, Pro Comp 6Al system. Mickey Thompson 275/50 Et Street Drag radials.
07-23-2008, 06:02 PM   #3 (permalink)
peterhill
Re: 24 vs 26 spline
No power shifting.
Shoot, now that you've bought that up I may have to go 26.
It's always been one of the options but because of the extra $$, finding a suitable core and new stall etc, I've always ummed and arred.
ATTN GREGAUST, if you're reading this , does a c4 from an XD/E have a 26 spline shaft? Cheers Peter.
07-23-2008, 07:20 PM   #4 (permalink)
Just Jim
Re: 24 vs 26 spline
The 24 spline early C4 will be just fine for your application. The no burnouts or racing is a bunch of BS. All 3 of my "hobby cars" have 24 spline C4's and get raced on a regular basis with no problems being 24 spline.
\'58 Morris Minor 289 S/S MM
07-23-2008, 10:15 PM   #5 (permalink)
gregaust
Re: 24 vs 26 spline
XD will be 26 spline.
To check the diameter of the shafts , late type is .839" early one is .788".
07-23-2008, 11:18 PM   #6 (permalink)
peterhill
Re: 24 vs 26 spline
Thanks Gregaust, Justjim amd Forthman for your replies.
Greg, so waddayareckon 24 or 26 . Cheers Peter
07-24-2008, 02:58 AM   #7 (permalink)
gregaust
Re: 24 vs 26 spline
Well i only build 26 splines now mostly. Particularly if you are looking to make power. It is easier to get converters also. My converter guy did one high stall 24 spline converter a few years ago and won't do another . Required a special inner hub.drive to be made up .The later ones have a better valvebody too in my opinion but valvebodies won't interchange.
So if you're in Australia ?? it's easy enough to get any 1970 onwards C4.
07-24-2008, 04:54 AM   #8 (permalink)
peterhill
Re: 24 vs 26 spline
So if i go to the wreckers , what should I ask for ? A late model c4 or a c4 from an 80's Falcon? Just worried that the counter salesperson might try to flog a pre 70. Or is it easier to ask the transmission rebuilder to get a core?
31, 33, or 35 spline loman All Ford Techboard 8 02-20-2008 05:14 PM
TCI converter fitment 26 spline to 24 spline 50dan C4 Transmissions 1 08-09-2007 08:31 PM
31 or 28 spline ellsauto Mustang Pages (1965-1973) 6 10-04-2006 07:22 AM
28 to 31 spline strokerman All Ford Techboard 11 11-26-2002 09:06 PM
Ford 9\" 31 spline diameter & spline depth Torino Pages 0 12-31-1969 05:00 PM
Powerhouse products
