09-10-2008, 07:04 AM   #1 (permalink)
nolimit2
vacuum modulator question with boost
I am going to install a stock c4 and have a question about connecting the vacuum modulator to the port on the back of my carb. I am running 15psi of boost and am not sure what that will do to the modulator?Anyone will any info would be great.
Thanks.
nolimit2 is offline   Reply With Quote
09-10-2008, 03:11 PM   #2 (permalink)
gregaust
Re: vacuum modulator question with boost
http://www.fordmuscle.com/forums/c4-...ulator-c4.html
Down the page a bit here is a valve you can use also
TH400 build-pictures - Page 7 - TurboBuick.Com
09-10-2008, 04:15 PM   #3 (permalink)
PSIG
Actually, I posted that style 1-way system I've used right here a while back. I believe my parts choices may be a bit better, as mounting angle (to keep the ball down) and gravity are not required. With far less operating mass it should be faster on both venting and recovery as well. Did you ever try it on yours, Greg? Any issues?
David
09-10-2008, 04:48 PM   #4 (permalink)
gregaust
Thanks Dave. I was actually looking for that one. I better save it now .. Not got to try that yet myself,been still using the manual valvebodies now that i have found a good one.
Vacuum Modulator-Simple Question umc2762 C4 Transmissions 5 02-10-2008 08:53 PM
Running boost with a modulator C4 gregaust C4 Transmissions 2 03-13-2006 04:26 AM
c6 vacuum modulator elsanyo All Ford Techboard 3 05-03-2005 10:24 PM
vacuum modulator etp20 Galaxie Pages 1 01-23-2004 11:17 PM
vacuum modulator gchero351 C4 Transmissions 1 12-07-2003 12:09 AM
