06-26-2009, 05:25 PM   #1 (permalink)
klu408
I need advice (c4)
First off let me say this is an awesome site!! Lots of info..
My question is I have a PA supercomp c4 and Im having trouble keeping high gear clutchs in it. We have had alto blues and reds and all have only lasted around 100 miles or so. The guy that rebuilds them for me is a backyard type guy and I dont think he does all the stuff I have read about on this forum.
My car is making over 800rwhp so I was wanting to know if it was the setup or am I at the limit of the clutches in the c4. It has 6 high clutches. Thanks alot.
klu408 is offline   Reply With Quote
06-26-2009, 11:52 PM   #2 (permalink)
PaulS1950
Re: I need advice (c4)
You are no where near the limit of the C4. Your builder is just not experienced enough to know that it can hold more clutches than 6. What mods have been made to the valve body, case, stator, pump and servo?
Paul's Street and Strip
Performance AODs & C4s
paulstephens@q.com
6522 51 Ave. S.
Seattle, WA. 98118
206.725.0881
06-27-2009, 12:13 AM   #3 (permalink)
klu408
I'm not sure. The valvebody is the billet one from PA and I'm not sure about the other stuff? Sorry to sound so stupid!! Is there anybody In Alabama that can make this thing work and last? Thanks
06-27-2009, 12:42 AM   #4 (permalink)
DanH
is that a 100 miles on the road, like with -- a cop behind you? how long did the original P/A last
06-27-2009, 06:57 AM   #5 (permalink)
klu408
The original one lasted along time but that when I was making 550 rwhp. Since I have changed setup and making more power is when it has been acting up.
06-28-2009, 07:35 AM   #6 (permalink)
klu408
Anybody have a suggestion?
06-28-2009, 08:25 AM   #7 (permalink)
Mario428
There is more than few people who can make suggestions but unless your tranny builder will take the advice and know what to do with it the advice may be a waste.
I would look at the pump, sealing rings on drum support, lip seals in direct clutch, end play, servo seals etc etc.
How does the tranny work, most importantly does the rpm flare on the 2-3 shift. At 800 hp that flare is a death sound.
http://img.photobucket.com/albums/v660/Mario428/T-BirdBurnoutsmall.jpg
06-28-2009, 11:59 AM   #8 (permalink)
klu408
Tranny works great shifts good and firm, and no flare but it will just melt the high gear clutches and weld them together. Is there anybody in my area that is capable of building this tranny to spec.
06-30-2009, 10:56 PM   #9 (permalink)
PaulS1950
You need to be running teflon sealing rings on the stator support and replace the direct clutch apply piston seals. You also probably need to run more clutches and higher pressure than the transmission was originally set up with. I would say 200 to 210 PSI. At that power level it should also be all roller thrust bearings with end play set between .004" and .006" total.
How much nitrous are you running?
blower?
paulstephens@q.com
6522 51 Ave. S.
Seattle, WA. 98118
206.725.0881
07-01-2009, 09:40 AM   #10 (permalink)
klu408
Its a 347 stroker with a 76MM turbo with 18 psi
Hello/any advice? Last427 Galaxie Pages 5 06-06-2006 10:54 PM
347 ADVICE ROBBDATHROB Stroker Engines 6 04-06-2005 03:45 PM
Help Need Advice! Craig All Ford Techboard 1 04-03-2005 02:41 PM
Need advice on 2V heads. Also cam advice. Rancho Lenny All Ford Techboard 3 10-22-2004 10:51 AM
Advice BLISTIC All Ford Techboard 13 01-19-2003 07:56 AM
