10-11-2009, 08:52 PM   #1 (permalink)
zigmont
C4 transmission fluid leak
I have a 66 C4 transmission in my 64 1/2 Mustang convertable. Whenever it sits for a while, the fluid in the torque converter drains back into the transmission and leaks out around the selector shaft. Is there a way to correct this with the transmission still in the car?
If I do have to remove the transmission, what do I have to do to fix the leak?
The transmission is great otherwise
zigmont is offline   Reply With Quote
10-12-2009, 02:03 AM   #2 (permalink)
gregaust
Re: C4 transmission fluid leak
Have a look , 2 seals in that area . Likely it is the small outer seal for the kickdown lever , is easily replaced incar by removing the 1/2" nut and lever , dig the seal out and put in a new one ..
10-26-2009, 04:56 PM   #3 (permalink)
natty
I have had some experience with the same problem. This was with a TCI C4 Streetfighter I bought new from TCI. It puddled transmission fluid on the garage floor everytime I drove the car.
You can change the selector shaft seal with the transmission in the car, but you must drop the valve body out the transmission. You can get a new seal at any auto parts store. The kickdown lever seal is just an o-ring and easy to change without opening the transmission.
Yes, I was angry that I had to change this seal after paying about $900 dollars for the transmission. Not only that, but the second time to the strip the forward drum inside the transmission split in half. I have since installed stronger built transmission from a different supplier.
natty is offline   Reply With Quote
C5 mysterious fluid leak..... BIG P C4 Transmissions 4 10-23-2007 04:49 AM
Bad fluid leak , need help ! bad4rd C4 Transmissions 3 10-01-2006 11:07 PM
Power steering fluid vs transmission fluid. my67mustake Mustang Pages (1965-1973) 4 09-09-2006 03:01 AM
Fluid leak Z400ryder8 C4 Transmissions 2 11-13-2005 01:39 AM
Low on fluid but no leak ??? Java Torino Pages 1 10-04-2003 12:43 PM
