10-21-2009, 05:57 AM   #1 (permalink)
zc347
C servo and servo mod
Hi, I'm building a C4 for a friend, it's full roller with kevlar bands, alto clutches, PA input and planetary. The auto already has a TCI full manual valve body, I've got a Sonnax C servo to go in it. Just wondering if it'll be ok to use the C servo with the TCI valve body. Will the apply force be too great with the servo mod done to the servo piston? Don't want to be splitting the case or band in 2.
cheers, Matt
zc347 is offline   Reply With Quote
10-21-2009, 10:28 AM   #2 (permalink)
PaulS1950
Re: C servo and servo mod
cheers, Matt
Don't use the servo mod with a high line pressure valve body! The "C" servo is fine all by itself - no need to mod it unless you are running more power than good sense. What servo is in it now?
Paul's Street and Strip
Performance AODs & C4s
paulstephens@q.com
6522 51 Ave. S.
Seattle, WA. 98118
206.725.0881
10-21-2009, 03:56 PM   #3 (permalink)
zc347
It has a modified H servo in it now.
I did email TCI about using an aftermarket servo with their valve body. They said it's ok to use but i don't need to grind the 3 slots, just remove the seal.
Has anyone not done the servo mod when using a valve body which instructs you do do it? Does it all still work fine?
10-22-2009, 03:50 PM   #4 (permalink)
gregaust
If you have a modified "H" already i wouldn't be wasting the $$ on the Billet "C"
10-22-2009, 05:56 PM   #5 (permalink)
PaulS1950
No need for it - the size of the larger piston is the same - It won't change a thing.
I would make sure to keep the bans adjusted or you are likely to end up with a broken case.
paulstephens@q.com
6522 51 Ave. S.
Seattle, WA. 98118
206.725.0881
10-23-2009, 08:37 PM   #6 (permalink)
zc347
Friend definitely wants to use the C servo. So should be ok if i don't do the mod and fit it then?
10-24-2009, 01:44 AM   #7 (permalink)
gregaust
If you modify the C servo it will be EXACTLY the same as the H that's in there now except he will have spent $$$ . By modifying and only using the inner seal both the C and the H have the same apply areas
Servo H SLOWJOE C4 Transmissions 1 06-17-2009 02:00 AM
PA Pro Shift Servo or stock H servo MrPer C4 Transmissions 1 09-16-2008 03:18 PM
servo\'s rickwestaus C4 Transmissions 4 11-14-2005 08:27 PM
R servo 64 TBOLT C4 Transmissions 0 07-01-2004 08:00 PM
A or H servo for C5 papadaddy C4 Transmissions 11 04-12-2004 10:44 PM
