10-24-2009, 11:25 PM   #1 (permalink)
av bronco
C4 trans temp
Just wondering if my temp is o.k.-68 bronco 427 windsor and 35" tires, in rad. trans cooler and hayden big dawg trans cooler with E. fan, gets up to 210-215 f. even on little hills or very small grades it shoots up to 210, stays there and cools off when I level off and is not slipping. also stock converter. trans is pretty new by a very reputable builder.
av bronco is offline   Reply With Quote
10-24-2009, 11:28 PM   #2 (permalink)
Stuarta
Re: C4 trans temp
Where is the sender located?
Wrench twister since 1957.
Journeyman in 1964.
Transmission builder since 1964.
Stuarta is offline   Reply With Quote
10-25-2009, 11:55 AM   #3 (permalink)
PaulS1950
Re: C4 trans temp
The C4 will have its longest life at or below 170F. At 210F the C4 will only last 1/4 of its expected life. You need to get more air through the cooler or add another cooler with a fan on it between the cooler you have and the rear line of the C4 for the longest life.
Paul's Street and Strip
Performance AODs & C4s
paulstephens@q.com
6522 51 Ave. S.
Seattle, WA. 98118
206.725.0881
10-30-2009, 01:04 PM   #4 (permalink)
chunger
Re: C4 trans temp
Not to conflict with what Paul said above me. But I recently put a temp gauge inline on my ranchero. I rebuilt the c4 years ago and only recently installed the temp gauge. It commonly reads 195-210, even on cool days.
This is a mild ranchero with a 302 and stock radiator (extra core added). Cooler in tank only. It might shorten the life, but I can say that mine's been running these temps for years without any adverse effects.
-chunger
'68 Ranchero 500
'70 Cougar XR-7 Convertible
'98 Mustang GT Convertible
chunger is offline   Reply With Quote
10-30-2009, 02:31 PM   #5 (permalink)
dacofa
Re: C4 trans temp
175-190 is a better anbd longer life temp. But sender location will make a diff on what temp you're seeing. Pan temp is after it's run thru the trans. If pan temp is 200 or less, good. If cooler outlet side is 210+, bad. Deeper pan and bigger cooler with maybe it's own cooling fan temp controled.
Lead, Follow, or get the F%$K out of my way.
11-02-2009, 10:01 PM   #6 (permalink)
chunger
Re: C4 trans temp
Good point, Dacofa. My temp sensor is on the line coming out of the trans, before the cooler. So, it's seeing the highest temp.
-chunger
'68 Ranchero 500
11-05-2009, 09:21 PM   #7 (permalink)
av bronco
Re: C4 trans temp
Yep, it's on the outlet side of the trans cooler line tee'd in at the inlet side of the rad. trans cooler. I just changed gears from 3.50s to 4.11s and it seems to run cooler but I havent taken it up any grades yet.
11-06-2009, 04:53 PM   #8 (permalink)
dacofa
Re: C4 trans temp
If possible I'd put one in the pan and one at the cooler outlet. I know it can be a hasle, put it will tell you if the cooler is big enough and working. Sometimes just a different location will make the difference.
You also don't want it to cold either. The metals and seals will not like that at all. Cold rubber seals will leak and break. That is what happened to the Space Shuttled Challenger when it blew up. The seals were cold and already cracked and brittle. When the extra pressure hit them, that was it. And did you also know that 3 of the Astronauts had water in their lungs. Because they were alive when the capsule hit the water. And one was tangled up in his safety straps.
Trans seller: Broader and FB Performance Trans Sponge C4 Transmissions 4 06-15-2009 04:01 AM
Trans oil temp gage denk C4 Transmissions 6 02-07-2007 10:58 PM
Anyone running a trans temp gauge...question xbolt427fe All Ford Techboard 8 06-24-2005 09:56 PM
trans temp gauge elsanyo All Ford Techboard 6 04-15-2005 08:01 PM
C4 TRANS TEMP SENSOR PLACEMENT Superman C4 Transmissions 3 06-16-2004 09:33 PM
