10-26-2009, 02:05 PM
mach169
manual valve body shifts 2-3rd auto
Hi
Have a manual valve body c4, 1st gear fine 5500 shift to 2nd then 4200 shifts by its self to 3rd! any idea's?
Allan
10-26-2009, 04:23 PM
gregaust
Re: manual valve body shifts 2-3rd auto
Sounds more like a B+M shift kit , not a manual VB. Some guys on here have had same issue the the B+M kits . Chris Kelly was one i think had similar prob??
10-27-2009, 01:53 AM
mach169
these are the only details i have from the guy i got it from
'Schuck Transmission' in California; full overhaul with Hughes bits, steel plate kit, new pump, drums, valvebody, clutches, bands, seals, filter.
Valve reprogramming kit, Makco #98472
sold a bad one?
10-27-2009, 03:11 AM
gregaust
sold a bad one?
Allan , maybe contact Transmission Parts Automatic Transmission Parts Order Transmission Parts Online they sell the Makco brand i think. See what they say . I couldn't find that part number .
10-27-2009, 05:07 PM
PaulS1950
sold a bad one?
You don't have a full manual valve body. What you do have is a valve body with a TransGo Reprogramming (tm) kit in it. You have manual control over 1 and 2 but once in the Drive position it will shift to high at normal governed speeds. You should be able to hold second gear manually for as long as you like but at WOT it will shift from the Drive position into 3rd with the governor.
Paul's Street and Strip
Performance AODs & C4s
paulstephens@q.com
6522 51 Ave. S.
Seattle, WA. 98118
206.725.0881
10-28-2009, 01:24 AM
mach169
Thanks for that Paul, is there any way of adjusting the shift rpm to 3rd?
Thanks Allan
10-28-2009, 12:39 PM
mach169
Also wot i am saying is the shifter is still in 2nd and not in "D" i cant hold it in 2nd??
10-28-2009, 02:07 PM
gregaust
That's right . As i mentioned search on here for CKELLY i think that was what he had with a B+M kit , switched to transgo fixed it .
10-28-2009, 02:18 PM
#9 (permalink)
gregaust
10-28-2009, 03:03 PM
#10 (permalink)
mach169
Thanks for that, so stick with it or change the V.B thanks for all the help guys.
Allan
