11-05-2009, 07:11 PM   #11 (permalink)
fordfan630
Re: used tranny-do i need a new front seal?
Thanks for all the info, I replaced the seals and put the tranny in the car know I need to figure out the kickdown. the car originally had a straight six with a 2 speed, i kept the engine but, like I mentioned earlier, i replaced the 2 speed with a c4. the 2 speed kickdown was made up of three rods, the first connected to the carb, the second went across the bell hosing, and the third attached to the kickdown arm on the tranny. I would insert a picture of it if i could find one Any ideas? all info is appiciated
fordfan630 is offline   Reply With Quote
11-05-2009, 07:19 PM   #12 (permalink)
It would only behoove you to tell us which of the several hundred models of FORD that you are putting this into...
There are a few different kick down systems... The C-4 is a Pull type.
Honor!
11-05-2009, 07:24 PM   #13 (permalink)
fordfan630
sorry, it's a 63 ford fairlane, I would just put a cable on it but a rod (like what was originally on it) is ment to PUSH, and a cable is ment to PULL, this is where I see the problem
11-05-2009, 07:36 PM   #14 (permalink)
If I could see the throttle system on your rig I'd be able to fab something up no problem.
Honor!
11-05-2009, 07:44 PM   #15 (permalink)
fordfan630
I don't know how to post pictures from my own collection, but I'll look on the internet for one, i know how to post pics that way all I can really discribe without too much confusion is that the plate along side the carb that the rod originally connected to swings toward the rear of the car when the accelerator is pressed
11-05-2009, 08:30 PM   #16 (permalink)
fordfan630
This is the best picture on the internet i could find, like I said before, I don't know how to insert pictures from my own computer, paste doesn't seem to work you can see on the pic of the 170, my set-up looks the same, sry it isn't very detailed
http://www.billwrigley.com/vintage/10.jpg
11-05-2009, 09:05 PM   #17 (permalink)
PaulS1950
Some C4s use the push method - a few others use the pull method. Both return to the "at rest" position so get under it and check which way it goes. You might find that you have a simple solution at hand.
Paul's Street and Strip
Performance AODs & C4s
paulstephens@q.com
6522 51 Ave. S.
Seattle, WA. 98118
206.725.0881
11-05-2009, 09:21 PM   #18 (permalink)
fordfan630
If a person had to they could just take the nut and arm off and put the arm back on-so it could go push or pull (if the arm pointed up, for instance, it can be removed and put back on pointinf down, as long as it doesnt interfere with the shifting linkage) I would need a longer third rod like I mentioned before- I just don't want it not working right and getting caught between gears, that's why I rather rig up a cable
Front seal afret C4 Transmissions 2 07-03-2008 05:20 PM
Leaking but not from front seal Fringe C4 Transmissions 3 06-19-2008 07:51 AM
c4 front seal bullet C4 Transmissions 1 05-17-2004 02:07 PM
How do you change the T5 rear tranny seal? andysam Late Model EFI Techboard 1 06-03-2003 06:36 PM
How do you change a T5 rear tranny seal? andysam All Ford Techboard 3 06-03-2003 12:45 PM
