10-27-2009, 09:14 PM   #1 (permalink)
fordfan630
used tranny-do i need a new front seal?
I'm installing a used c4 into my ford, I heard from the previous owner of the tranny in I don't replace the front seal it is a guaranteed leak. Is this true? If so, whats the best way to replace it? any info is appreciated I don't have much experience with automatic trannys
fordfan630 is offline   Reply With Quote
10-27-2009, 09:24 PM   #2 (permalink)
gbic1
Re: used tranny-do i need a new front seal?
I would change it or have it done if you dont have a driver. Seals take shape and if it has been sitting out of a car the converter will drop down and push down on the seal. If you do it your self then pack the back of the seal with Vasolone to keep the spring from falling out.
1964 Galaxie 428
1966 Mustang 302
1967 Cougar 390
1968 F250 Camper Special 390
10-27-2009, 11:00 PM   #3 (permalink)
gregaust
Yes definitely good insurance to change it out
10-28-2009, 06:32 AM   #4 (permalink)
Front AND Rear....
Honor!
10-28-2009, 11:48 AM   #5 (permalink)
fordfan630
i'v heard of people installing the seals by usint a piece of pipe instead of a puller. i don't have a puller nor the right size pipe How else can I install it? Can I just tap it in with a block of wood going in a circular motion? (first tap at 12 o-clock, second at 1, third at 2...........) i've done this before with O seals
10-28-2009, 02:06 PM   #6 (permalink)
gregaust
Yes you can as long as you are careful and go steady
10-28-2009, 03:42 PM   #7 (permalink)
Stuarta
The old seals can be pried out with a screwdriver.
Then tapped in with a hammer.
Apply some sealant to the exterior of the seal because there could be some seepage.
Wrench twister since 1957.
Journeyman in 1964.
Transmission builder since 1964.
Stuarta is offline   Reply With Quote
10-29-2009, 01:17 AM   #8 (permalink)
PaulS1950
Be sure to lube the sealing surface of the seal and the snout of the converter or you can ruin the seal in minutes.
Paul's Street and Strip
Performance AODs & C4s
paulstephens@q.com
6522 51 Ave. S.
Seattle, WA. 98118
206.725.0881
11-03-2009, 05:37 PM   #9 (permalink)
jd75
For sure do the front and rear, only a few bucks each. I take the old one out set the new one in and place the old one on top of it. Then a block of wood and easy taps. Using the old seal helps because its the same diameter as the new one and the block will distribute the pressure needed to get it to seat. And i always alternate with the hammer, 12 then 6 then 11 then 5 and so on. Basically if you start at 12 and just go around clockwise they seem to get wedged in on that one side and dont go in straight.
jd75 is offline   Reply With Quote
11-04-2009, 02:46 AM   #10 (permalink)
mmerlinn
Do you really want to take a chance of having to pull the transmission back out to replace a nickel-and-dime seal?
mmerlinn (http://mmerlinn.com) -- "Careless and sloppy writers are usually also careless and sloppy at thinking. Answering questions for careless and sloppy thinkers is not rewarding." - Eric Raymond
mmerlinn is offline   Reply With Quote
Front seal afret C4 Transmissions 2 07-03-2008 05:20 PM
Leaking but not from front seal Fringe C4 Transmissions 3 06-19-2008 07:51 AM
c4 front seal bullet C4 Transmissions 1 05-17-2004 02:07 PM
How do you change the T5 rear tranny seal? andysam Late Model EFI Techboard 1 06-03-2003 06:36 PM
How do you change a T5 rear tranny seal? andysam All Ford Techboard 3 06-03-2003 12:45 PM
