Go Back   FordMuscle.com Forums > Premier Forums > Tech Exchange > Cooling Articles
01-19-2009, 06:39 AM   #11 (permalink)
qtrracer
Re: Junkyard Upgrade - Dual Electric Fans
This looks like the dual fan Ford put on the Contours. If so, DCC (Delta Current Control) has some specs on their site as well as controller packaging, etc. Look for integral fan #33212.
qtrracer is offline   Reply With Quote
01-19-2009, 07:35 AM   #12 (permalink)
cramer
Hello,
This is the fan that is found on Ford Contour and Mercury Mystique so the schematics you posted a link to look good (33212 Information).
Thanks,
Marc Cramer
cramer is offline   Reply With Quote
01-19-2009, 12:23 PM   #13 (permalink)
roger
Did you ever get the dimensions of the fan set up?
I;d like to use on my F;lane but i;m not sure how close the Mustang/F;lane's are in rad size.
Very nice job & great write up by the way.
thanks
roger is offline   Reply With Quote
01-19-2009, 12:26 PM   #14 (permalink)
roger
Sorry, missed that
Are you saying his Contour fan install is same size/type as #33212?
01-19-2009, 02:10 PM   #15 (permalink)
cramer
Originally Posted by roger View Post
Sorry, missed that
They look pretty much exactly the same except in the fan image on the schematic page they have some additional holes on the bottom of the shroud, where they are hooking the wiring together, that don't exists on mine.
Based on the schematic and what I have measured and verified against other peoples measurements you should be pretty good to use those specs, at least for the height width and depth of the fans and shroud.
Somebody else had measured and they got
"...24" wide, 16" tall, and about 3.4" deep at the deepest point"
Marc Cramer
01-25-2009, 05:47 PM   #16 (permalink)
mn64falcon
can this dual fan setup be used on a 64 falcon convertible?
i am swapping in a 302 on stock suspension.
Mike
Northland Falcon Chapter | Member Coordinator
MSRA #17719 | FCA #12684 | 3M Rod & Custom Club
mn64falcon is offline   Reply With Quote
01-26-2009, 02:16 PM   #17 (permalink)
cramer
Hello,
Not sure, but probably.
Really depends on the amount of space in your engine bay .
I used the stock radiator from a 1969 mustang coupe, with AC.
Marc Cramer
01-31-2009, 03:42 AM   #18 (permalink)
tomstir
Where did you find that fan for $95????? Great deal!!!!
65 fastback 64 falcon sedan delivery
non stock- no quarter -searching for piece -3 pedal
tomstir is offline   Reply With Quote
01-31-2009, 07:38 AM   #19 (permalink)
cramer
Hello,
95.00?
I picked up the fan at a local Pick-N-Pull (Pick-n-Pull » Home), junkyard where you pull your own parts, for around 25.00 and it comes with a 30 day exchange/return for credit policy.
Marc Cramer
02-13-2009, 07:43 PM   #20 (permalink)
DaveBoyer
Awesome! Thanks for the info!!
DaveBoyer is offline   Reply With Quote
HTML code is On
Junkyard disk brake upgrade on a 8 inch rearend ujt389 All Ford Techboard 7 01-20-2009 12:12 PM
Junkyard Upgrade – Tilt Steering Column cramer Interior Articles 4 10-23-2008 08:47 AM
Junkyard Upgrade – Seats cramer Interior Articles 10 08-22-2008 06:51 PM
Junkyard electric fan questions: Cupcake65 The Garage 3 04-02-2007 05:57 AM
Dual fans. 72Torino Torino Pages 3 05-26-2006 04:19 PM
Probe Industries
