10-19-2007, 08:11 PM   #1 (permalink)
strtcar
First Time Drag Strip 10am Saturday..Any Estimates?
Going to the track in 13 hours for the first time in 10 years (with me racing). I'm so excited can't wait, weather is looking like 65 and sunny.
Any estimates on what I might run?
1967 Mustang Coupe (no a/c or heater box, fairly light)
345HP Ford Racing 302 Crate
C4 2500 Stall
3.70 9"
275/40/17 M/T Drag Radials
13's I hope, but what you guys think?
[SIGPIC][/SIGPIC]
1967 Mustang Coupe
[URL="http://chicago-classic-mustangs.com/"]http://chicago-classic-mustangs.com[/URL]
10-19-2007, 08:22 PM   #2 (permalink)
blown68
Re: First Time Drag Strip 10am Saturday..Any Estimates?
13.40, tire pressure to 16 and do a good burnout.
blown68 is offline   Reply With Quote
10-20-2007, 06:21 AM   #3 (permalink)
strtcar
THanks, ill keep you posted tonight when I get back
[SIGPIC][/SIGPIC]
1967 Mustang Coupe
10-20-2007, 09:24 AM   #4 (permalink)
ga289stocker
First time to strip is always a nervous experience. I think car just from
hp # alone could go low-mid 13's. But on a first trip, there is always bugs
to work out, I'm saying 14.50's. Any suspension mods? I'd guess car is about 3100 lbs, best of luck and kept us posted.
It's so darn fun. Make sure your hand isn't shaking to bad when you pick up your time slip, mine sure was. I was pumped up on adrenaline...
1965 Mustang 2+2:stock headed 289, Weiand 7515, Holley 600 dp, Tri-y's, 3.80 trak-loc, 4sp,Ram Air 13.83 @100.97
ga289stocker is offline   Reply With Quote
10-20-2007, 10:11 AM   #5 (permalink)
frdnut
You should run well into in the 13s..The only thing iffy I see in your combo is maybe the torque converter is a little tight for good launches?...My combo with a 4 speed and 4.11s ran 13.70s and I was only making about 270ish hp according to the calculators.
I did uncork the headers and removed the power steering belt to get those numbers as well..In true street form with sticky tires I ran a best of 13.98...Without the sticky tires I was running mid to high 14s.
10-20-2007, 03:46 PM   #6 (permalink)
strtcar
Well little dissapointed, got a best of 14.0@100, 2.0 60ft. Thats with me leaving it in drive and it shifted at 4800. I think mid 13's are in order if I shifted it manually 5600-5800rpm.
One problem I have is I can't break torque the car past 1100rpm without it wanting to move. Is that cause my torque converter is too tight?
[SIGPIC][/SIGPIC]
1967 Mustang Coupe
10-20-2007, 07:02 PM   #7 (permalink)
BIGJOE
That means you need about at least a 3500 stall converter to really get the job done.The rated stall speed is almost allways way off. ( like in your case)too bad .
JOE SHERMAN RACING ENGINES
10-20-2007, 07:20 PM   #8 (permalink)
n2omike
That 4800rpm shift point is also killing you.
Of course, as Joe said, the first 60ft are the most important when it comes to good et's.
Find a way to launch it harder, then shift it at 6k rpm!
Good Luck!
66 mustang
10-20-2007, 10:40 PM   #9 (permalink)
frdnut
The good news is you've got a decent mph that should see you well into the 13s...A higher shift point and a higher launch and your there no problem if you can get it to hook.
10-21-2007, 07:23 AM   #10 (permalink)
FoMoCo
Set it up right and you will see the very tip of 12's
Time Warp Drag Strip 673904spd The Garage 10 06-21-2005 12:35 AM
Saturday nite..............movie review time. deleted The Garage 3 06-05-2005 11:56 AM
My Saturday night is almost complete, time for Red Green uriah The Garage 4 01-02-2005 01:02 PM
Need tips on drag racing at a drag strip. BobsSleeper The Garage 16 10-28-2004 01:33 PM
Estimates on my Qtr mile time, Am I taking a risk? mikemustang289 All Ford Techboard 15 10-12-2004 09:33 PM
