10-21-2007, 12:15 PM   #1 (permalink)
f100cleveland
Went drag racing for the first time yesterday
Went to a local NHRA 1/8 mile track for a test and tune. Ended up running 9 times in about a 3 hour period. I had MAJOR problems on the launch all day. Tried about everything but couldn't find any sort of a sweet spot. My 60' ranged from 1.832-2.025. Over half the runs I had to get total out of the throttle twice cuz the rear tires were trying to leave the track. Towards the end of the day, I just stayed in it and it would kinda-sorta recover but would end up with a lot of wheel spin. I included 3 videos that all have different launches.
This pass was leaving off of the foot brake at about 3000 rpms. Converter flashes to 5000, so it hits pretty hard. Ran a 1.903 60', 8.029 @ 89.85. 1.5 turns preload on both sides for Caltracs, 7/7 on Rancho 9000's, 14 psi in the 325/50r15 M/T ET Streets. Seemed to kinda initially spin and then hook and bounce.
This was the quickest ET pass. Ran a 1.881 60', 7.976 @ 89.90 mph. Foot brake to about 3500, 2 turns preload on right, 1.5 turns left, 4/4 on shocks, and 14 psi in tires. Just seemed to hook really hard on this pass and bounced hard twice before I got out of it.
Should've left parts on the track on this pass. Looks like the rear end drops down a foot and the left rear comes right off the track. Went off the transbrake with the 2 step set @ 4200 rpms. Had a 1.961 60' time, 8.033 @ 90.07 mph. Had 2 turns preload on right, 1.5 turns left, 4/4 on shocks, 12 psi in tires.
The best MPH I ran was a 90.18 and according to Chris Kelly's calculator, it takes about 470 rwhp to push my 4200# truck that fast in the 1/8. But, since its a truck, I'm assuming it takes a little more cuz of the added wind resistance. That equates to about a 12.4 quarter.
As for the Caltracs, the front mount is in the bottom hole and the rear mount is in the bottom hole too. I tried adjustments from zero preload to 2 turns and seemed to be the worse at about the zero preload. I didn't have my springs clamped, so not sure if that caused these problems. Tried air pressure in the ET Streets from 12-16 psi. Also tried the shocks from 4/4, 4 left/5 right, 5/5, 7/7. Seemed the worse on 7/7. I'm thinking a set of real slicks would help me too. Not sure if I'm shocking the tires so hard that they can't recover? Would a set of dedicated drag slicks be able to handle this shock better, hence the wrinkle sidewalls? I think there is a lot more in the truck if I can just get it to hook and not bounce. I appreciate any help on rear suspension solutions.
1982 F100 2wd-408c CHI 3V 225cc Heads
675hp and 576 ft lbs @ the flywheel on pump gas
f100cleveland is offline   Reply With Quote
10-21-2007, 12:48 PM   #2 (permalink)
1 Bad 88 GT
Re: Went drag racing for the first time yesterday
Have you considered a four link?
07 Victory Vegas Jackpot
93 F150 4.9, AOD(winter beater)
89 5spd Coupe, 351C EFI Spyder, AGS 4 suspension
80 LX 11:1 carb'd 351C w/GForce T5, 17x9 95 R's(daily driver).
10-21-2007, 12:52 PM   #3 (permalink)
gchero351
What is yer rearend gear ratio ? btw, that was awesome-
dude,do a poppa-willie!
gchero351 is offline   Reply With Quote
10-21-2007, 01:12 PM   #4 (permalink)
BLstangin
His rear gear ratio is a 4.86. I was with and can say it was impressive, would love to see what it'll run with the launch figured out.
1970 mustang coupe restored with the help of my dad soon to be 438 dart block based stroker, afr 225, super victor,BIGS 950hp, accufab 2\" primary headers, solid roller cammed, 4speed toploader, 9\" 3.50 gears, locker
BLstangin is offline   Reply With Quote
10-21-2007, 05:44 PM   #5 (permalink)
dennis111
Too tight of a shock setting defeats the functioning of the Caltracs. As you figure out on you own, run the shocks loose (maybe even 2 or 3.)
You will need some preload and Calvert recommends starting at 1/4 turn. You will probably need to increase it some to make up for the softer shock setting, but 2 turns seems excessive. Top setting on the front of the Caltracs hit the hardest. Not sure what the rear setting that you mentioned is though.
Dennis
11.25@122.19mph
10-21-2007, 06:23 PM   #6 (permalink)
BIGJOE
What happens if you launch from just above idle ??I have never seen a car turn a faster time when you must lean on the converter so hard. The lower you stage, the more torque multipacation you will get. The trans brake leave has NO torque multipacation at all. Most cars I have worked with run much better when they foot brake it on the starting line. The transbrake is only to get a better reaction time when bracket racing.
JOE SHERMAN RACING ENGINES
11-14-2007, 03:03 AM   #7 (permalink)
smblktbolt
I have a 3300 (actual) stall and a transbrake. so you are saying that i would be have a faster 60ft (and possibly overall et) if i kept foot braking instead of using my stall? i plan on stepping up to a 4000 stall, would this still hold true or is there a point where it no longer makes a difference? curious to know as i have previously footbraked to a 12.22, then last year after a few "improvements" i managed a 12.29 with a 10tnth slower 60ft after trying out the transbrake. interesting......
351w fairlane
lots of fiberglass
even more bondo!
smblktbolt is offline   Reply With Quote
11-14-2007, 09:24 PM   #8 (permalink)
f100cleveland
Actually, the new rear suspension is almost done. I went with a S&W Race Cars ladder bar kit. I jumped onto a Ford Lightning forum and guys either run the 56" bars that mount under the axle and go up to the frame, just below the seats, or a few guys ran the ladder bar setup. We should have mine done this weekend. Too bad the tracks are closed now and won't be able to see how much it helped or hurt it.
11-14-2007, 09:26 PM   #9 (permalink)
f100cleveland
Joe, after reading that, it makes more sense. I was looking at my time slips and the ones that I footbraked at the lowest RPMS had the best 60', but due to the terrible bounce I got from the better launch, I had to get out of it more so the ET or MPH wasn't as good. I'll be sure to try the right off of idle launch this next spring.
11-14-2007, 09:29 PM   #10 (permalink)
f100cleveland
The two turns was excessive and just made me spin. I talked to Calvert a couple different times about this and never got any real definate answers. I got on a Lightning board and only a couple guys had had any luck with the Caltracs on a truck like mine. The guys that did were pure drag trucks with 6500 rpm converters leaving off the 'brake. So, I'm trying my luck with a ladder bar setup.
Drag Racing ujt389 The Garage 10 04-26-2005 06:24 PM
Need tips on drag racing at a drag strip. BobsSleeper The Garage 16 10-28-2004 01:33 PM
road racing or drag racing????? IAPEXL8R The Garage 19 03-28-2002 04:32 PM
drag racing justink All Ford Techboard 3 02-27-2002 05:17 AM
