02-14-2008, 05:07 AM   #41 (permalink)
jasonn
Re: Finally!! Got the 10 sec slip!!
Originally Posted by Lupins View Post
Hey Jason Im in the process of puting together A 69w as well. Did you have to make any special mods for valve to piston clearance? Thicker head gaskets or cut the pistons? Any info or part numbers would be a great help. I have AFR 205's and a airgap intake. I just need to figure out the rest.
Sure do have some info!! The rotating assm is made for a 9.5" deck height. 69 blocks are machined to AROUND 9.48. I say around cause the factory does not do it to exact spec. Took minimal to clean it up but it still puts the pistons out of the hole. Mine ended up being around (if I remember correctly) .021 out of the holes. I was not going back and machining pistons, and rebalancing the assm. So I got some Cometic head gaskets that were like .060 thick. That keeps your .038-.040 quench. This works great on mine. I have over 3 years on the motor and have never had a problem. Piston to valve clearance was a ton. If you get a good aftermarket piston, they will have alot of clearance machined right in. But you STILL need to check it. Mine was a Scat rotating assm from A.D. performance. Had probe dished pistons. Brian can tell you exact part #'s and he is the cheapest I could find. Very knowledgable also.
1970 Mach 1
mild 351w 12.51@108
70 Tubbed, narrowed fastback
Mild 408w 10.83@123
jasonn is offline   Reply With Quote
02-14-2008, 07:57 PM   #42 (permalink)
Lupins
Great info thanks!!
Lupins is offline   Reply With Quote
5-speed slip a lil ndmus88gteng All Ford Techboard 2 10-16-2007 05:12 PM
How much slip should be exposed on a slip yoke? f100cleveland All Ford Techboard 10 06-07-2007 09:39 PM
AOD and C-4 slip yoke cdeal28078 All Ford Techboard 4 06-15-2003 09:08 PM
limited slip doesn't limit slip anymore Matte All Ford Techboard 4 09-01-2002 09:49 AM
Limited Slip 8" AZ65coupe All Ford Techboard 6 08-11-2002 03:15 PM
