03-15-2008, 06:18 AM   #1 (permalink)
Gydyup
Rear End set up
Any ideas on this, when I go back and look at my launch tracks you can see the initial patch, then the tracks make a noticable shift/jump towards the driver side - then a nice set of straight tracks.
Stock springs, with slapper bars, so not a lot of science in this, just never seen it before.
Gydyup - 67 Mustang Coupe
\"old School\"
03-15-2008, 07:40 AM   #2 (permalink)
KULTULZ
Re: Rear End set up
Have you tried pre-loading the bars? Locking the front spring leafs together?
This is assuming you have a TRACTION-LOC and the clutch pack is good.
03-15-2008, 12:44 PM   #3 (permalink)
Gydyup
Re: Rear End set up
Yes, I have it pre loaded with the front hoops on the bars, equal load where there snubbers are about a 1/8 inch from contacting the springs.
Its a spool so the power is equal to both tires, and looking at the contact patch and resulting rubber on the drive way, appears to be equal load each wheel.
I dont have the slicks on it right now, using street radials until I get this figured out. Wonder if it could be a weak spring. The prev owner, who ran it on the track, had a wedge under the pass side, I took it out to level the car. I also had a bit of twist or something when I would shift hard or dump the clutch, taking the wedge out took a lot of that out. but it still is making a visible shift to left, just dont feel it as much as I used to.
\"old School\"
03-15-2008, 01:16 PM   #4 (permalink)
KULTULZ
Re: Rear End set up
50/50 drag shocks I guess? Maybe the right rear is coming up enough to make it walk sideways?
Maybe AIR-LIFTS or an extra leaf in the right side to pre-load it?
CAL-TRACS?
The best way I think is to have someone tape the launch with a movie camera and that may tell you what is going on.
Will an 8.8" rear bolt up to 1995 Mustang LX rear mounts? blykins Mustang Pages (1979-1995) 5 01-24-2008 07:27 PM
SSBC rear disc conversion for 65-66 Mustang 8\" rear ga289stocker All Ford Techboard 10 11-08-2005 06:40 AM
Why A Price Difference Between R.Rear And L.Rear Brake Roters 77ltd All Ford Techboard 4 08-23-2004 12:08 PM
8.8 cougar rear into fox stang w/ t-bird TC rear disc conv. or 5 lug conv. with rear disc Foxbodystang All Ford Techboard 1 11-30-2003 08:36 PM
Lincoln rear disc brakes on 8\" rear end fordracerguy All Ford Techboard 4 09-08-2003 09:43 PM
